Authorise.net test mode not working in your server Invoice Ninja
we will get error for test mode. Please check.
Are you seeing a specific error?
You may want to check that test mode is set correctly in the gateway settings on Settings > Payment Settings.
1)Local Environment … I got an HTTPS required error. (this is test mode only. why need https).
2)Your server(Invoice Ninja)=> while clicking the pay now it shows merchat error
- Please allow http for test mode. It is working in version 4.
It is not working in version5.
2)For your server , we got below error =>Receiving error while processing your payment
are you using invoicing.co ? it is not possible to use http on invoicing.co so we’d need to know the exact problem you are seeing. I’ve tested auth.net in test mode and it is working ok for me.
The most common issue we see with auth.net is Customer Information Module not being enabled.
Please allow http for test mode. It is working in version 4. => this is for my local environment. I have tested with testmode in local environment but it gives error “HTTP required”
Ok but it is working in version 4. May i know any resirction is there for PDF view.
[2022-07-20 08:26:44] testing.ERROR: Server error: POST https://pdf.invoicing.co/api/
resulted in a 504 Gateway Timeout
response:
I am facing this issue in docker environment
