Assign project to other client
is it possible to move a project from one client to another? I can not find an option for this.
Background information:
A client was bought by another company. The name and address is now different. But there are older projects i have not invoiced - which i now have to invoice to the new company.
Merging the old company into the new one is no option - because the old invoices should be the same as they were.
Also i can not create a draft invoice and then set the new customer, because when i save the draft i can not change the company.
Thank you,
Regards, Andreas
Sorry, it isn’t supported.
Ok. Thank you for the fast answer. :slight_smile:
So i will create these again manually.
Regards,
Andreas
