Version <v5.10.54>
Environment
Checklist
- Can you replicate the issue on our v5 demo site https://demo.invoiceninja.com or Invoice Ninja? Yes, shows up there too.
- Have you searched existing issues? Yes, to no avail.
- Have you inspected the logs in storage/logs/laravel.log for any errors? No
Describe the bug
Applying a WL license I just bought puzzled me for a few minutes. The key I received last year was exactly 24 char long. The new key is more then 30 chars long. The input pop-up for the license key has a character counter at the right bottom saying “0/24”. I can enter up to 24 chars, then it stays at “24/24” and also doesn’t echo any further chars on the screen.
It took me a minute to overcome my reluctance to accept the fact that the last chars of the key won’t show up and to press “submit” anyway. The key was accepted and the Plan now shows as “white label”, but from a UI point of view this needs fixing.
Steps To Reproduce
Expected Behavior
Show a char counter like “0/50”, or whatever you expect the maximum number of chars in a lic key to be and then echo all those chars.
