I know that I can set the tax name and value for invoice items in the json call, for example:
{“client_id”:2,“invoice_items”:[{“qty”:1,“tax_name1”:“USt.”,“tax_rate1”:“16%”,“notes”:“Renew domain.com”,“product_key”:“DE-DOMAIN”}],“email_invoice”:0}
In the invoices, I see that there is alternatively the option to set the tax rate on the whole invoice instead of every single item. Setting tax_name1 and tax_rate1 next to the client_id doesn’t work.
Since I’m unable to find a complete API documentation, how can I archive to set the tax to the invoice instead of every single item?
This would help a lot since it seems the only way to work around the tax rounding errors of Invoice Ninja.
So, when creating invoices in the frontend, I can select tax for the invoice instead of every single item.
Problem is, that I don’t know how to do the same when using the JSON API.
When I’m setting the tax_rate1 in the invoice_items array, it works, but with the problem that rounding errors occur because tax is added to every item, then rounded, then summarized.
When I omit the tax_rate1 in the items, no tax is added at all. So I assume I have somehow to add the tax_rate1 to the invoice itself, but I can’t find out, how exactly to do this.
FWIW, you’re probably not going to be able to use the tax numbers from IN anyway.
In NY, the state calculates “what you owe” based on total sales for the period, not the total of what you collected on each invoice.
Because each sale almost certainly rounds up or down a little, if you add up the tax from each invoice, it’s probably not going to to match what the state wants, which is based on total sales.
I ended up writing a SQL Query that I run at sales-tax time.
So, as expected, now I got problems with my tax accountant.
As already stated, I can use “tax on summary instead of single items” on invoices generated via API call, but unfortunately this doesn’t work with recurring invoices.
Now I have hundreds of recurring invoices where tax is calculated per-item, rounded, and then summarized, which means that most of them are calculated wrong.
Is there any way how to fix that?
And why doesn’t this bother anyone else?
