I’m trying to get api to work via Power Automate.
The api works fine via CMD. But when I try it through Power Automate I get the message “Invalid Token”. The values are the same.
I assume that the empty value at X-Api-Secret is the cause. Does anyone have the link working?
Or maybe another solution is not to leave it blank on X-Api-Secret. But where can I adjust this value? Changing API_SECRET to .env has no effect.
Indeed the X-Api-Secret was not the problem. In fact, you can enter any value there.
The problem was in the header. For the authorization I chose Raw under advanced options and filled the header there without ". See the image and now it works.
