I’m currently running v4.x self hosted with a number of integrations using the API, creating customers, invoices and invoice items
If I upgrade to v5.x will my API calls break, or are they portable between versions?
Thanks!
Terry
Thanks!
Terry
The v4/v5 APIs are mostly the same but there are a few differences noted here:
https://invoiceninja.github.io/docs/developer-guide/#migrating-from-v4
Thank you!
I’ll try the new install, and see how many integrations go.
