Hi.
Updates works great, but I always need to run it twice in order to loose the ! sign and to show the latest version?
Why is that so?
Thank you
Br,
Dali
Hi.
Why is that so?
Thank you
Br,
Dali
Are there any errors in the logs when the first update fails?
Do you see a memory limit warning in the health check dialog?
No errors.
All seem to go smoothly, and at the end app restarts, refreshes.
But still the triangle ! and old version is showing. After second update it always works. It happens every single update.
Br,
Dali
I will make a screen video for next update. Maybe I can send some logs if you need. Please advice.
Thank you
Br,
kd
I’ve found I have to restart php-fpm / php(version)-fpm, but clicking thru the install process twice I think worked a time or two as well during the time I was trying to figure out what was going on. The restart works reliably for me.
Still I always need to to a update 2 times. Every single update the same.
Br,
Dali
What is the server PHP memory limit set to? We recommend 512MB.
Yes it’s 512mb
