Hi
How do I adjust column width in the header of the invoices? My email address is bursting onto 2 lines.
Also, is it possible to change “Invoice” to “Tax Invoice”
Hi
These changes should be possible by customizing the design. If you let me know which design you’re using I’ll try to provide exact instructions.
Hi Hillel
I’m using the clean design.
Clark
On /settings/customize_design change from ‘Form’ to ‘Code’
Add “width”: 200,
on line 12 to increase the width of the column.
Change $entityTypeUC
on line 27 to ‘Tax Invoice’. Note this change will also affect quotes.
Perfect thank you! Great product!
