Hi there,
I always have this issue when adding text in the description of the quotes, I cant seem to find a way to successfully add spacer between each number line and or paragraph I added within the same item. Any recommendations around this?
Thank you
Is the PDF markdown option enabled on Settings > Account Management?
If it is disabling may help or you can leave it enabled and add two line breaks.
@hillel, disabling PDF markdown did the trick. Thank you very much for pointing me to the right direction.
