I am a new InvoiceNinja user (running self hosted v. 4.5.7) and I am also a full stack developer. I’m not very familiar Laravel but I’ve used others MVC frameworks in PHP.
I am planning to add a button to get a pop up window with products (searchable not only on ref, but also on Notes and Price) to be able to add quickly many products. If I get through with this: do you accept Pull Requests ? what are the guide lines to get the code accepted ?
I am thinking to add a little button either in front of the last row or underneath it. I’ve found the code displaying the table at resources/views/invoices/edit_table.blade.php.
Is this code all “InvoiceNinja” home made or using external libraries (like datatables or others) ? I can see there a few libraries loaded (bootstrap, jqueryUi, knockout) but I am not sure which ones are at work on the table.
Any thing I should know to make that change ?
Cheers,
L@u
