Is it possible to insert an image into the invoice footer? I’m trying to place a QR code png for mobile payments into the invoice footer area and tried editing the custom invoice design under footer. I was looking at this website but not sure if I referenced the image correctly as it does not seem to work and has errors above the preview section. I tried both a url reference and placing the image directly in the root invoiceninja folder and just referencing it as ‘qrcode.png’.
I’ve no coding experience so if anyone can point out specifically what is wrong, I would greatly appreciate! Thank you!
I’ve used an online converter to get the base64 string for my image and pasted it via the admin panel but seem to be getting an error. (error here: https://i.imgur.com/D4eo3MV.png)
Is there an issue pasting the long string into the editor?
sorry for the late response. But I just noticed this on the pdfmake website
“// Warning! Make sure to copy this definition and paste it to an
// external text editor, as the online AceEditor has some troubles
// with long dataUrl lines and the following image values look like
// they’re empty.”
Could it be the image string is too long and cannot be pasted on the online editor under Settings > Customize Design? Is there a file I can edit externally on a text editor and upload?
