ADDING CUSTOMER CARDS
Ww are using Authrize.net as our gateway on our self hosted setup and are trying to figure out if customers can add cards and set up auto billing (card is charged after recurring invoice comes due) or if we need to use another gateway.
Also we have seen mention of being able to add our clients cards manually ourselves (as we can do in Wave Accounting)
I have looked at the documentation but can’t find anything specific on cards related to Auth,net.
Sorry, it isn’t supported
So what gateways are supported for this?
CAn I get a bit more detail on your answer?
Token billing is supported with WePay, Stripe, Braintree or GoCardless.
So in other words, firms that bend you over on the rates and wont let you use your own MID.
Great. I really thought I had a solution with Invoice Ninja. Guess I’ll have to keep looking,
