Trying to add contact name, email, and phone number onto an invoice. Is this possible? Doesn’t seem so.
Also, I wanted to add additional information to the Contact Name such as Job Title…any thoughts?
Thanks,
Ajay
Thanks,
Ajay
You’d need to create a custom invoice design as well as modify the code used to generate the PDFs to make the fields accessible. Note: use we Grunt to concatenate the JS files to built files.
https://github.com/invoiceninja/invoiceninja/blob/master/public/js/pdf.pdfmake.js
Is it possible with the hosted version? I’m also trying to add the name of the contact in the invoice using $client.contact.name
but it does not work.
Try ["$contact.firstName"," ","$contact.lastName"]
Note: you’d need to use ‘Code’ view
Perfect!
Would be nice to add it in the documentation
Noted
