Hi there, just moved over from Waveapps. I really like InvoiceNinja, only thing I miss is to add receipts to my non-billable expenses. Does it exist and i just can’t find it or do I need to find a workaround?
Thanks in advance.
Thanks in advance.
Sorry, I removed my past (incorrect) responses.
Yes, this is supported. If you’re using invoiceninja.com it requires an enterprise plan.
Thank you - found it.
