Is it possible to define a scope for an account.
Example:
UserA can work on ClientA and ClientB
UserB can work on ClientC and clientD
They are supposed to only access to their clients.
Example:
Sort of…
Users can have permission to just records they create so it would work if User A creates Clients A and B.
I am generating bills from API, can I set the user attached manually?
You should be able to use separate tokens for each user, I’d suggest testing it.
