I use Invoice Ninja [v5.3.39] as self-hosted on a shared-web-hosting server. Whenever I make any changes to the settings and try to save, I get a popup saying - “500: Server Error”.
Not able to use the application to its fullest potential because of this. I am restricted to using it only with the default setting - without being able to customize any options. Any support I could get would be much helpful.
@hillel, Thanks for the reply.
It says I am running the latest version. Even while force updating from here, it says “update completed”. But I don’t see any change after that.
