As the last part of my attempt to migrate to v5, I was trying to use the Forward customers to v5 area in settings, but whenever I clicked on submit, I would get a 500 error. When I checked the logs, I saw:
Column not found: 1054 Unknown column 'is_disabled' in 'field list' (SQL: update `account_email_settings` set `is_disabled` = 1, `forward_url_for_v5` = https://mydomain, `account_email_settings`.`updated_at` = 2021-11-22 14:35:28 where `id` = 1
so I went into the db and sure enough, those columns were not present for some reason. So I created them (is_disabled as INT, forward_url_for_v5 as VARCHAR), ran the command again, and this time it worked. I am just documenting this here in case it helps someone else. No idea why those columns were missing from the db, but this fixed it. (I hope)
If you’re missing a column in the database the most common reason is a database migration needs to be run. You can run it with this command: php artisan migrate
I ran the upgrade script to upgrade to the latest v4 version (which I had run for every v4 version prior). Was there something new in the latest upgrades that made that script no longer valid? it was:
It sounds like your migrations were not up to date on your v5 installation, you needed to run php artisan migrate on v5, i would have concerns about the state of your application now that you have manually created those columns.
Seems superficially ok I guess because when I run the migrate command now I get this:
Migrating: 2021_06_22_234707_add_forward_url_for_v5
In Connection.php line 669:
SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'forward_url_for_v5' (SQL: alter table `account_email_settings` add `forward_url_for_v5` t
ext not null default '', add `is_disabled` tinyint(1) not null default '0')
In PDOStatement.php line 107:
In PDOStatement.php line 105:
