dan0
January 18, 2023, 12:32am
#1
Our selfhosted InvoiceNinja v5 instance is experiencing 500 errors when I email invoices manually or apply a payment to an invoice.
I also had an invoice disappear on me, the payment record still exists and is showing a negative value (whereas $574.60 was charged to the clients card) but the invoice 7954 is gone from the client’s invoice view
I did run the following command inside the InvoiceNinja folder earlier when sending the email about this invoice failed. I was able to send the email after running this.
sudo find ./ -type d -exec chmod 755 {} \;
Here are the logs from today as well: NCrypt - Paste
January 18, 2023, 5:12am
#2
Can you please post the specific error you’re seeing in storage/logs?
dan0
January 18, 2023, 6:06am
#3
Hi @hillel , this is the stack trace of the aforementioned error:
[2023-01-17 23:51:42] production.ERROR: Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3zjqsrws/invoices. {"userId":1,"exception":"[object] (App\\Exceptions\\FilePermissionsFailure(code: 0): Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3zjqsrws/invoices. at /var/www/invoiceninja-v5/app/Jobs/Entity/CreateEntityPdf.php:218)
#0 /var/www/invoiceninja-v5/app/Listeners/Invoice/CreateInvoicePdf.php(42): App\\Jobs\\Entity\\CreateEntityPdf->handle()
#1 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(236): App\\Listeners\\Invoice\\CreateInvoicePdf->App\\Listeners\\Invoice\\{closure}()
#2 /var/www/invoiceninja-v5/app/Listeners/Invoice/CreateInvoicePdf.php(43): Illuminate\\Support\\Collection->each()
#3 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Events/CallQueuedListener.php(107): App\\Listeners\\Invoice\\CreateInvoicePdf->handle()
#4 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Illuminate\\Events\\CallQueuedListener->handle()
#5 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Container/Util.php(41): Illuminate\\Container\\BoundMethod::Illuminate\\Container\\{closure}()
#6 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\\Container\\Util::unwrapIfClosure()
#7 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\\Container\\BoundMethod::callBoundMethod()
#8 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Container/Container.php(651): Illuminate\\Container\\BoundMethod::call()
#9 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(128): Illuminate\\Container\\Container->call()
#10 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Bus\\Dispatcher->Illuminate\\Bus\\{closure}()
#11 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#12 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Bus/Dispatcher.php(132): Illuminate\\Pipeline\\Pipeline->then()
#13 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(124): Illuminate\\Bus\\Dispatcher->dispatchNow()
#14 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Queue\\CallQueuedHandler->Illuminate\\Queue\\{closure}()
#15 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#16 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(126): Illuminate\\Pipeline\\Pipeline->then()
#17 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/CallQueuedHandler.php(70): Illuminate\\Queue\\CallQueuedHandler->dispatchThroughMiddleware()
#18 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/Jobs/Job.php(98): Illuminate\\Queue\\CallQueuedHandler->call()
#19 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/SyncQueue.php(43): Illuminate\\Queue\\Jobs\\Job->fire()
#20 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Queue/Queue.php(57): Illuminate\\Queue\\SyncQueue->push()
#21 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(591): Illuminate\\Queue\\Queue->pushOn()
#22 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(515): Illuminate\\Events\\Dispatcher->queueHandler()
#23 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(441): Illuminate\\Events\\Dispatcher->Illuminate\\Events\\{closure}()
#24 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Events/Dispatcher.php(249): Illuminate\\Events\\Dispatcher->Illuminate\\Events\\{closure}()
#25 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/helpers.php(451): Illuminate\\Events\\Dispatcher->dispatch()
#26 /var/www/invoiceninja-v5/app/Services/Invoice/MarkSent.php(69): event()
#27 /var/www/invoiceninja-v5/app/Services/Invoice/InvoiceService.php(180): App\\Services\\Invoice\\MarkSent->run()
#28 /var/www/invoiceninja-v5/app/Http/Controllers/EmailController.php(141): App\\Services\\Invoice\\InvoiceService->markSent()
#29 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(236): App\\Http\\Controllers\\EmailController->App\\Http\\Controllers\\{closure}()
#30 /var/www/invoiceninja-v5/app/Http/Controllers/EmailController.php(146): Illuminate\\Support\\Collection->each()
#31 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\\Http\\Controllers\\EmailController->send()
#32 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\\Routing\\Controller->callAction()
#33 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Illuminate\\Routing\\ControllerDispatcher->dispatch()
#34 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\\Routing\\Route->runController()
#35 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(798): Illuminate\\Routing\\Route->run()
#36 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
#37 /var/www/invoiceninja-v5/app/Http/Middleware/UserVerified.php(43): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#38 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\UserVerified->handle()
#39 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#40 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequest()
#41 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()
#42 /var/www/invoiceninja-v5/app/Http/Middleware/QueryLogging.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#43 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\QueryLogging->handle()
#44 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#45 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#46 /var/www/invoiceninja-v5/app/Http/Middleware/Locale.php(46): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#47 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Locale->handle()
#48 /var/www/invoiceninja-v5/app/Http/Middleware/TokenAuth.php(96): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#49 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\TokenAuth->handle()
#50 /var/www/invoiceninja-v5/app/Http/Middleware/SetDb.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#51 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\SetDb->handle()
#52 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#53 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\\Pipeline\\Pipeline->then()
#54 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\\Routing\\Router->runRouteWithinStack()
#55 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\\Routing\\Router->runRoute()
#56 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\\Routing\\Router->dispatchToRoute()
#57 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\\Routing\\Router->dispatch()
#58 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
#59 /var/www/invoiceninja-v5/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#60 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\\DisableBrowserCache->handle()
#61 /var/www/invoiceninja-v5/app/Http/Middleware/Cors.php(25): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#62 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Cors->handle()
#63 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#64 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Http\\Middleware\\TrustProxies->handle()
#65 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#66 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#67 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
#68 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#69 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#70 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#71 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#72 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
#73 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#74 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
#75 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#76 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\\Pipeline\\Pipeline->then()
#77 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#78 /var/www/invoiceninja-v5/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
#79 {main}
[2023-01-18 00:00:17] production.INFO: available credit balance = 0
[2023-01-18 00:00:17] production.INFO: Auto Bill - balance remains to be paid!! - 118.700000
[2023-01-18 00:00:40] production.INFO: Auto Bill payment captured for R7954
[2023-01-18 00:05:12] production.INFO: available credit balance = 0
[2023-01-18 00:05:12] production.INFO: Auto Bill - balance remains to be paid!! - 574.600000
[2023-01-18 00:06:30] production.ERROR: Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3zjqsrws/invoices. {"userId":1,"exception":"[object] (App\\Exceptions\\FilePermissionsFailure(code: 0): Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3zjqsrws/invoices. at /var/www/invoiceninja-v5/app/Jobs/Entity/CreateEntityPdf.php:218)
#26 /var/www/invoiceninja-v5/app/Repositories/BaseRepository.php(109): event()
#27 /var/www/invoiceninja-v5/app/Repositories/InvoiceRepository.php(73): App\\Repositories\\BaseRepository->delete()
#28 /var/www/invoiceninja-v5/app/Http/Controllers/InvoiceController.php(767): App\\Repositories\\InvoiceRepository->delete()
#29 /var/www/invoiceninja-v5/app/Http/Controllers/InvoiceController.php(613): App\\Http\\Controllers\\InvoiceController->performAction()
#30 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Collections/Traits/EnumeratesValues.php(236): App\\Http\\Controllers\\InvoiceController->App\\Http\\Controllers\\{closure}()
#31 /var/www/invoiceninja-v5/app/Http/Controllers/InvoiceController.php(615): Illuminate\\Support\\Collection->each()
#32 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\\Http\\Controllers\\InvoiceController->bulk()
#33 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(43): Illuminate\\Routing\\Controller->callAction()
#34 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(260): Illuminate\\Routing\\ControllerDispatcher->dispatch()
#35 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Route.php(205): Illuminate\\Routing\\Route->runController()
#36 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(798): Illuminate\\Routing\\Route->run()
#37 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}()
#38 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#39 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequest()
#40 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()
#41 /var/www/invoiceninja-v5/app/Http/Middleware/QueryLogging.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#42 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\QueryLogging->handle()
#43 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#44 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#45 /var/www/invoiceninja-v5/app/Http/Middleware/Locale.php(46): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#46 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Locale->handle()
#47 /var/www/invoiceninja-v5/app/Http/Middleware/TokenAuth.php(96): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#48 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\TokenAuth->handle()
#49 /var/www/invoiceninja-v5/app/Http/Middleware/SetDb.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#50 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\SetDb->handle()
#51 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#52 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\\Pipeline\\Pipeline->then()
#53 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\\Routing\\Router->runRouteWithinStack()
#54 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\\Routing\\Router->runRoute()
#55 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\\Routing\\Router->dispatchToRoute()
#56 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\\Routing\\Router->dispatch()
#57 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
#58 /var/www/invoiceninja-v5/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#59 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\\DisableBrowserCache->handle()
#60 /var/www/invoiceninja-v5/app/Http/Middleware/Cors.php(25): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#61 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Cors->handle()
#62 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#63 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Http\\Middleware\\TrustProxies->handle()
#64 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#65 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#66 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
#67 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#68 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#69 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#70 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#71 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
#72 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#73 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
#74 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#75 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\\Pipeline\\Pipeline->then()
#76 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#77 /var/www/invoiceninja-v5/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
#78 {main}
January 18, 2023, 6:18am
#4
@david do you have any ideas?
david
January 18, 2023, 6:30am
#5
The error is indicating a permission issue on the directory
dan0
January 18, 2023, 6:31am
#6
I did run the following command from /var/www/invoiceninja-v5 as root, which temporarily fixes the issue, then it randomly crops up again…
dan0
January 19, 2023, 9:22am
#7
I encountered this error again when creating an invoice on the same client profile as earlier.
500: Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3zjqsrws/invoices.
Here is what the Laravel logs show:
[2023-01-19 09:17:13] production.ERROR: Unable to create a directory at /var/www/invoiceninja-v5/public/storage/tf5ohehkafg4xcdrmufsqob4jd6lwymt/Wlw9PgSrycWsXelBr1tHviGvuotoGHYbMTWWjDM2/mwugbo72x5pqr3cencd6kfsk3
#28 /var/www/invoiceninja-v5/app/Services/Invoice/TriggeredActions.php(50): App\\Services\\Invoice\\InvoiceService->markSent()
#29 /var/www/invoiceninja-v5/app/Services/Invoice/InvoiceService.php(247): App\\Services\\Invoice\\TriggeredActions->run()
#30 /var/www/invoiceninja-v5/app/Http/Controllers/InvoiceController.php(229): App\\Services\\Invoice\\InvoiceService->triggeredActions()
#31 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\\Http\\Controllers\\InvoiceController->store()
#37 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(126): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#38 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/ThrottleRequests.php(62): Illuminate\\Routing\\Middleware\\ThrottleRequests->handleRequest()
#39 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\ThrottleRequests->handle()
#40 /var/www/invoiceninja-v5/app/Http/Middleware/QueryLogging.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#41 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\QueryLogging->handle()
#42 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(50): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#43 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle()
#44 /var/www/invoiceninja-v5/app/Http/Middleware/Locale.php(46): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#45 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Locale->handle()
#46 /var/www/invoiceninja-v5/app/Http/Middleware/TokenAuth.php(96): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#47 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\TokenAuth->handle()
#48 /var/www/invoiceninja-v5/app/Http/Middleware/SetDb.php(40): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#49 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\SetDb->handle()
#50 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#51 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(799): Illuminate\\Pipeline\\Pipeline->then()
#52 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(776): Illuminate\\Routing\\Router->runRouteWithinStack()
#53 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(740): Illuminate\\Routing\\Router->runRoute()
#54 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Routing/Router.php(729): Illuminate\\Routing\\Router->dispatchToRoute()
#55 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(190): Illuminate\\Routing\\Router->dispatch()
#56 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(141): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}()
#57 /var/www/invoiceninja-v5/vendor/livewire/livewire/src/DisableBrowserCache.php(19): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#58 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Livewire\\DisableBrowserCache->handle()
#59 /var/www/invoiceninja-v5/app/Http/Middleware/Cors.php(25): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#60 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): App\\Http\\Middleware\\Cors->handle()
#61 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Http/Middleware/TrustProxies.php(39): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#62 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Http\\Middleware\\TrustProxies->handle()
#63 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#64 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ConvertEmptyStringsToNull.php(31): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#65 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ConvertEmptyStringsToNull->handle()
#66 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#67 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TrimStrings.php(40): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle()
#68 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\TrimStrings->handle()
#69 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#70 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle()
#71 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/PreventRequestsDuringMaintenance.php(86): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#72 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(180): Illuminate\\Foundation\\Http\\Middleware\\PreventRequestsDuringMaintenance->handle()
#73 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(116): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}()
#74 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(165): Illuminate\\Pipeline\\Pipeline->then()
#75 /var/www/invoiceninja-v5/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(134): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter()
#76 /var/www/invoiceninja-v5/public/index.php(57): Illuminate\\Foundation\\Http\\Kernel->handle()
#77 {main}
Perhaps some part of this clients data is corrupt?
System forgets writing permissions seems to be a similar issue.
uname -a:
Linux billing 4.19.0 #1 SMP Thu Apr 22 16:18:59 MSK 2021 x86_64 GNU/Linux
lsb_release -a:
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux bookworm/sid
Release: n/a
Codename: bookworm
dan0
January 22, 2023, 3:14am
#8
@hillel & @david I really appreciate your help with this!
The client data in MariaDB was not corrupt, I was just a silly person doing the wrong thing by adding the Cronjobs as root, while the webserver’s PHP ran as www-data.
To fix this issue I moved the crontab and fixed the file permissions.
Remove the InvoiceNinja cron entries by opening crontab with:
crontab -e
Then cut the 3 lines and move them to the correct crontab:
crontab -e -u www-data
Finally fix the file permissions:
chown -R www-data:www-data /var/www/invoiceninja
cd /var/www/invoiceninja
find ./ -type d -exec chmod 755 {} ;
Hope this helps someone else who has trodden down the wrong path!
