Raki
1
I wasn’t able to login with my login credentials. I always got this error message: 500 Server Error.
I’m using the selfhosted version in Docker. Latest version.
I already checked nginx error log and docker-compose log, but got no new information about this issue.
Just to test: I changed my password and disabled 2FA. After then, I was able to login via other browser again.
What’s happend? My old login data was 100% correct.
Are there any errors in the logs in storage/logs/
Raki
4
It seems like, the key was changed or my frontend pushed the wrong informations?
Right, this error can occur if the value of APP_KEY in the .env file is changed
Raki
6
I’m sure, nobody changed this value
Maybe it’s something else, @david any thoughts?
david
8
The only way this can happen is if the APP_KEY changes.
Raki
9
But why it works again, if I changed my pwd and disabled 2FA?
david
10
@Raki
Not sure, I’ve tested this locally on both docker and regular installations and i cannot recreate the issue.
12
@david in v4 we encrypt the 2FA key which can also trigger the “MAC is invalid”, could it be related?
Raki
13
Any update? I would like to enable 2FA again
