I’m receiving the below listed error when I try to add or modify columns in reports and when trying to enable a module, such as Tasks. It may produce this error other times, but these are the only things I’ve found so far. I was running v5.10.4 and updated to v5.10.24 thinking it may have been an update issue, but the error still persists. I assume this may be related to some nginx settings?? Also, this issue persists across multiple apps. I have tried on iPadOS, Windows app and it appears to not work on web also. Web only states “something went wrong.”
Your help is appreciated.
Error: please check that Invoice Ninja v5 is installed on the server
URL: http://192.168.1.29/api/v1/company_users/VolejRejNm?
Response: <html>
<head><title>413 Request Entity Too Large</title></head>
<body>
<center><h1>413 Request Entity Too Large</h1></center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
Headers: {connection: close, content-type: text/html; charset=utf-8, date: Mon, 19 Aug 2024 16:57:11 GMT, content-length: 192, server: nginx/1.18.0 (Ubuntu)}} ```
@northhill please see below, and thank you. FYI I am using NPM as a reverse proxy and it contains my SSL cert.
server {
# NOTE That the 'default_server' option is only necessary if this is your primary domain application.
# If you run multiple subdomains from the same host already, remove the 'default_server' option.
listen 80;
# listen [::]:443 ssl http2 default_server;
server_name my.domain.com;
# client_max_body_size 20M;
# This if statement will forcefully redirect any connection attempts to explicitly use the domain name.
# If not, and your DNS doesn't provide IP address protection, accessing the server with direct IP can
# cause glitches with the services provided by the app, that could be security, or usability issues.
# if ($host != $server_name) {
# return 301 https://$server_name$request_uri;
# Here, enter the path to your invoiceninja directory, in the public dir. VERY IMPORTANT
# DO NOT point the root directly at your invoiceninja directory, it MUST point at the public folder
# This is for security reasons.
root /usr/share/nginx/invoiceninja/public;
gzip on;
gzip_types application/javascript application/x-javascript text/javascript text/plain application/xml application/json;
gzip_proxied no-cache no-store private expired auth;
gzip_min_length 1000;
# Enter the path to your existing ssl certificate file, and certificate private key file
# If you don’t have one yet, you can configure one with openssl in the next step.
# c ssl_certificate "/etc/nginx/cert/ninja.crt";
# ssl_certificate_key "/etc/nginx/cert/ninja.key";
# ssl_session_cache shared:SSL:1m;
# ssl_session_timeout 10m;
# ssl_ciphers 'AES128+EECDH:AES128+EDH:!aNULL';
# ssl_prefer_server_ciphers on;
# ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
charset utf-8;
# Load configuration files for the default server block.
include /etc/nginx/default.d/*.conf;
location / {
if (!-e $request_filename) {
location ~ \.php$ {
# Here we pass php requests to the php7.4-fpm listen socket.
# PHP errors are often because this value is not correct.
# Verify your php7.4-fpm.sock socket file exists at the below directory
# and that the php7.4-fpm service is running.
fastcgi_pass unix:/run/php/php8.2-fpm.sock;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
location ~ /\.ht {
deny all;
location ~* \.pdf$ {
add_header Cache-Control no-store;
location = /robots.txt { access_log off; log_not_found off; }
access_log /var/log/nginx/ininja.access.log;
error_log /var/log/nginx/ininja.error.log;
sendfile off;
# server {
# listen 80;
# server_name my.domain.com;
# add_header Strict-Transport-Security max-age=2592000;
# rewrite ^ https://$server_name$request_uri? permanent;
EDIT: The answer is yes. I enabled client_max_body_size 100M reloaded nginx and all is working as it should. Not sure what the approproate value should be, but I can say that 100M works. Hope this helps someone else.
