I thought I follow the guide pretty well, but seems I am missing something. I can only load invoiceninja from subdomain.domain.com/index.php
. navigating to subdomain.domain.com
redirects me to subdomian.domain.com/dashboard
with displays 404. Also, even though I can access from index.php, I still get 404 errors for manifest.json and logo which are visible in js console on chrome…
Other posts indicate to ensure mod rewrite is enabled which it is… not sure what the gap is… maybe RewriteBase isn’t configured properly? (already tried a few variants there with no success…)
$ a2enmod rewrite
Module rewrite already enabled
public .htaccess contains the following:
<IfModule mod_rewrite.c>
<IfModule mod_negotiation.c>
Options -MultiViews
</IfModule>
RewriteEngine On
# Redirect Trailing Slashes...
RewriteRule ^(.*)/$ /$1 [L,R=301]
# Handle Front Controller...
RewriteRule ^ index.php [L]
## enforce https access
## RewriteCond %{SERVER_PORT} 80
## RewriteRule ^(.*)$ https://%{HTTP_HOST}/$1 [R,L]
# http://stackoverflow.com/a/20865084/497368
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# In case of running InvoiceNinja in a Subdomain like invoiceninja.example.com,
# you have to enable the following line:
RewriteBase /
</IfModule>
root .htaccess contains the following
RewriteEngine On
RewriteRule "^.env" - [F,L]
RewriteRule "^storage" - [F,L]
RewriteRule ^(.well-known)($|/) - [L]
# https://coderwall.com/p/erbaig/laravel-s-htaccess-to-remove-public-from-url
# RewriteRule ^(.*)$ public/$1 [L]
</IfModule>
VirtualHost *:443 within apache ninja.conf contains the following directory info pointing to /var/www/html/ninja/ninja/public/
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerAdmin webmaster@host.com
DocumentRoot /var/www/html/ninja/ninja/public
<Directory “/var/www/html/ninja/ninja/public”>
Options +FollowSymlinks
AllowOverride All
Require all granted
</Directory>
I don’t see any interesting logs, but console does who 404 on index.php/logo and index.php/manifest.json
